hi all my 944 86 lux broke down over three weeks ago now and i am still trying to figure what it could be
apart from buying any parts except a dme relay i have just been testing thing but think i need to spend some now as im getting nowhere as such ??
my taco and fuel gauge has never worked since owning the car so i have no taco bounce but know there petrol in as low level works
had 8o mile spin the week before it broke
aa man on first breakdown said i had one of these but had one sensor on so think its your sensor so towed me home ,
2nd aa man said coil after i was getting some petrol after swapping but then putting back old relay as it fired up
so after doing the normal searches ect checked sensors using youtube method sensor
also made a little tester to check but cant find link at mo only my post on tipec link which has died so i thought i would try on here
it would run for about ten mins after leaving it a day and taking off earth lead so not to drain battery but today as of now she wont start at all which might be better so to speak
so upto now i have
checkd sensors i have no oscilloscope just multi meter
change dme relay
done 3 wire link pump working felt it ?
check 12 volt pin 35 dme
took off one fuel inj wire to see if it ran pressure ??
check coil seems ok as getting flash of timing light when switching on ignition
the annoying thing is i had an oscilloscope but cant find it to check the sensors properly as i just dont want to go out and buy parts that may not need replacing unless there cheepish
any one on here use a bmw sensor
bmw
sorry post might be a bit confusing as im in between looking for scope and fault finding outside and slightly going round in circles prob due to not spending my hard earned
thanks for any help
so upto now i have
change dme relay
bmw
thanks for any help
