OBC retro-fit - PST can't find instruments cluster
- Thread starter g_gribbin
ORIGINAL: g_gribbin
Nick,
Where are you, I might take you up on your kind offer, although I am also tempted to go back to the guys in Wembley who fitter the air bag de-activation as they should have a PST-2.
I am just outside Gerrards Cross. I am around the next couple of days but then in Shanghai for a week.
Like Richard I have performed this 'hack' on many a 986/996 indeed I installed the OBC and Cruise Control on our 986.
I might have the wrong end of the stick here but is your problem that when you do a search with PST2 your not getting any options under 'Instrument cluster'. If so you have do ask Nick points out, there will be nothing or 3 dashes in the area for 'TYPE', enter 986321 and do another search, it will then reveal the options under 'Instrument cluster'.ORIGINAL: Nick_USA
.... However, once the instrument cluster problem is corrected and assuming it has not been done the Order Type will have to be re-entered in the DME to allow the coding of the OBC function.
For the UK the model type is 986321 I believe. The US variant is 986320 for a 2003 S model.
I had the same problem fitting a cruise stalk.
Just a thought. The fuse chart on the wiring diagrams shows fuse B10 as "Instrument Cluster Diagnosis". It would be worth checking the fuse.
The a/c works fine too, one thing is a bit odd, when not in "Auto" it is in "Manuell" mode (not a type by me) do they all say this?
