Going to do an oil change first thing to the new Mobil 1 that I have.. but have a daft question:
The car is on the drive where I will do the change and has been all night - so should I just drain the oil now when its all cold and probabily all the oil has all drained into the sump overnight, or do you recommend I get the oil to running temp first, let it settle for a bit, then drain?
Cheers Ant
Cheers Ant
