markrwadsworth
Ok, after some thoughts on the issue I have....
996 C4S had an amount of oil in the usual places when I bought the car. When the clutch was replaced, the guys at Dovehouse (who I would thoroughly recommend to anybody) replaced the Rear Main Seal and Intermediate Shaft Seal. All was fine.
After a couple of months the oil had returned (covered a couple of hundred miles). Dovehouse took the gearbox back out and replaced the seal under warranty.
The car has just been in for new coffin arms, control arms and track rod ends. The oil is back and I asked Dovehouse to have a look. They are pretty confident the seal is right this time (the last one was a faulty part, not their workmanship) andwill take the gearbox back out to check the seal and will replace if it is faulty. If however the seal isnt faulty I could have a more sinister problem on my hands?
In other people's experience, where else could the oil be from if it isn't the RMS?
1. Imternediate Shaft bearing letting oil by - about to give up?
2. Porous crank casing?
3. Other?
Thoughts and experiences appreciated.
The car has 94k miles, full service history, no expense spared, everything else is perfect - just the niggling "what-if" with the golden drip!!!
3. Other?
