A couple of weeks ago I took a call from a very distressed female 2004 26000mile FSH Boxster S owner whose engine had "blown up". She had bought the car from a non Porsche outlet when it was just over three years old and the "warranty" she had only covered work up to £6000 including a strip down to confirm failure.She was being quoted approx £9500 to fix the problem.
I gave her the IMS saga well chronicled in this forum suggesting this was the probable cause and suggested engine replacement was the only option, also this was a well known fault which affected some Boxsters
On checking with her today she had contcted her local OPC with her tale of woe and they agreed to replace the engine and fund the difference if her seller's warranty coughed up the difference which they did.
She is a happier bunny although concerned and actually quite shocked that a car from a maker with a reputation for quality i.e. Porsche could have such a fault and even with my limited knowledge I could tell her that this fault is not that rare as we get to hear of most of these failures due to the catastophic results to engine and posibly wallet.
I would say that if you have your car regularly serviced with an OPC or others, don't have the Porsche extended warranty, and you suffer this failure make a stink at your OPC, bend their ears for a goodwill payment. Incidentally £9500 for a fitted replacement 2004 Boxster S engine does this sound right?
Regards.
