Interesting PH article from Opie. On reading it makes sense. Starting my apprenticeship (decades ago!) big plant diesels were where I focussed. One of the things I took on board were oils and additives, or detergents rather. Diesel oils then used high detergent additives - high compression ratios, harder working engines blah blah... I ran for a while a completely rebuilt classic Ford engine on a purely high detergent diesel oil. Ideal then as it kept all parts nice and clean with low carbon/sulphur build-up etc. Starting with a non-high additive/detergent oil (mineral or most semi-synths) then switching many years later to a fully synth higher detergent oil 'flushes' away some of the deposits that actually help create seals between some non-moving surfaces. It used to be said that you could hear the difference if you switched with parts seemingly 'clattering' more. Thought this might be interesting guff to some anyway. My engine, like many probably, is a high miler. That there 10W60 Opie review is very relevant I guess. Too thick and and you risk a bit more local hot-spotting (more potentially with air cooled engines too). I remember reading that Porsche on some of the works engines actually opened up some of the oil-ways to improve flow. A too 'thicker' high temp oil isn't going to be as efficient through those oil-ways as something slightly less thicker. A 0W arguably is better then a 5W or 10W on cold starting. I believe a very important factor, despite what people forget (or even say today), is the old adage of letting the oil warm up first before engine loading. A low value cold start oil reduces any momentary 'dry running' which easily is one of the most damaging/wearing things that can happen. I always seem to end up full circle with this one with all the impassioned debates on this. I want a low cold start oil but not the synth diesel type (which most/all are). There are a couple semi-synths around of 5W40 but not on the Porsche A40 list but I might investigate these anyway. In the meantime my 140k is more than happy it seems on 10W40 Mobil for the time being - and using less oil than the handbook suggests! Marcus
