oil
- Thread starter vimal
ORIGINAL: Richard Hamilton
Sorry Paul, but i think you have got that the wrong way round. Both 0W-40 ant 5W-40 have nominally the same viscosity when hot. 5W is thicker than 0W when cold.
Hi Richard,
So, is the "5W" part of the rating measured on a different scale from the "40" part? - because obviously the oil must be less viscous at high temperature. This has always confused me about oil ratings. But like you I have always understood the "W" part to be the Winter viscosity.
Or does "-40" means "minus 40"?!
Mark
The "0W", "5W" and "40" are in fact ranges. When comparing viscosities of oils, it is best to compare the kinematic viscosities in CentiStokes, which is a true value for the oil's thickness.
Hopefully this chart will make it a bit clearer:
You're right, I hadn't understood the oil ratings correctly.
However, after your last post I think I understand !
Your last chart shows what I expected, that all of the oils have higher viscosity cold than hot - which I guess most people would intuitively think is right - hot oil is "runnier" (to use the technical term !).
I'd therefore (incorrectly) assumed that the lower rating must indicate the hot viscosity. From what you've explained & shown in chart in your first post, the rating for hot & cold viscosity is totally different - even if the viscosity is still measured with the same Cst units.
Its good to learn something new every day !
Paul
2004 996 C2 40th Anniversary
I'd be interested to see the viscosity figures for Mobil 1 5W-40 if anyone has them to compare with the 0W-40, but only out of "interest" - I'm not sure that I'll do anything different![8|]
thirteeneast
5w-40w
I use Miller or Fuch from Opie.
thirteeneast
For what it costs yes, I change my oil every year or 6k.
Mine actually only does 3k-4k before I change the oil.
I would never leave it till 12k. I don't think its cost effective.
andyjwhit
how many miles has your 996 done? Mine has 118K on the clock. I do about 12K a year so I could change oil twice a year at 6K. When you say cost effective are you refering to engine blow up then??
Would have thought modern synthetic oil would still be doing a good job at 12K, some modern service intervals go up to 18K?? I guess if you are only doing 3K a year then oil would require changing due to lack of use, if you see what I mean.
Bst
Andy
thirteeneast
In fact my heads a mess with Fully synthetic oil
I change my oil regular mainly because its the same cost as a tank of gas and could save me a bill of £££££.
It doesn't take long and is the single most important part of your car I don't let any of my cars do more than 6k before an oil change.
Not even the banger I use for work it just makes no sense.
If theres anything wrong your going to pick up on it 6k earlier.
Just my choice of course but a small price to pay in grand scheme of running a Porsche. (or any car)
Mine has 54k on the clock and gets used every weekend problem is the millage/use is split across three cars so therefore is less on all.
andyjwhit
Bst
Andy
I would say use an approved 5W-40 synthetic, and change it every 6000 miles, and you won't go far wrong.
