skendrick
Hi, can anyone help me with my turbo overboosting and cutting out my engine. I recently found that I have a 'Boost Enhancer' on my 944 turbo and during the summer I decided to turn it up a couple of notches to see the difference. [
] Wow, manure and shovel sprang to mind when I pressed the loud peddle, until the engine cut out 30 seconds later [
]. Started the car back up, whent home sensibly and de-tuned the car back down.
I haven't been using my car reguarly for the last 6 weeks as my wife gave birth to our second child (well, through the sun roof), so I've been using her car. I took my car out the weekend and gave it a burst of power only to find the turbo overboosted and cut out the engine again. Maybe I need to turn it down one more notch but I was wandering do you get more pressure in hot weather or cold because if you get more pressure in the cold then this will need to be turned down anther notch for the winter and I don't want to miss out on that additional power.
Does anyone know the answer or have a similar problem?
Thanks for reading
Steve
Thanks for reading
Steve
