ORIGINAL: 333pg333
ORIGINAL: Neil Haughey
ORIGINAL: 333pg333
It all sounds good Neil. Can you remind me what your car finished up weighing after ditching all the OEM parts listed?
Hi Patrick, it weighed 1130 Kg with 4 gallons onboard. This includes btw fully working pop up headlights, electric windows and OEM exhaust. With me in it 1202 Kg which puts me 12Kg over the class 2 limit. With my new Dansk exhaust on the car could well be right on the limit. If I take the headlights and a few other things off the car I will have to stick some lead ballast in the passenger seat area.
Thanks Neil. I'm not sure what the S2 exhaust weighs but the turbo version is really quite heavy. I would assume that going to fixed lights, non steel doors, new exhaust, you would be well under your class weight limit. As you say though, you can re ballast lower in the car so that's something for the future. Makes me hopeful that mine might sneak in around the 1100kg mark without driver. Bigger wheels/tyres/brakes plus extra turbo stuff will count against me vs your car so should be about the same as yours I'm hoping. Also hoping to know that in a few weeks.
Re the OEM LSDs, I'm 95% sure they were a 40/40 plate type. My mechanic terms them as a good sports / trackday car setup but not up to the rigors of Motorsport. I had to have mine rebuilt a couple of times just doing trackdays. Having had the 50/80 Motorsport LSD setup in the old 951 (S2 r/p) I can't say I really noticed any noticeable understeer. Maybe in really slow hairpins but that could easily have been wheel/tyre, suspension geometry as well. Now going with 968 trans w KAAZ 6 plate setup 45/90. So many other changes though, so won't be able to truly compare.
