sawood12
I've read something by Jackie Stewart that might be the steering input thing you've mentioned. He said that if you start your steering input slowly and accellerated the rate at which you turn the wheel instead of quickly snapping the wheel round at a constant speed it allows the car to settle on it's suspension before the maximum lateral G is exerted. The result is a much smoother ride for the passengers and the car is able to make a much tighter turn or make the turn at higher speeds than if you simply turned the wheel. He demonstrated this by driving a car round a track with a cup of coffee on the dashboard at a decent pace without spilling a drop. The technique can also be applied to braking - intead of simply stamping on the brakes, bring the braking force up to max quickly but steadily. This allows you to ultimately apply more braking force and if mastered reduce braking distances. I think this technique is basicly all about doing things smoothly and efficiently.
I've been using/practicing the steering technique and it is definately better. My other half is particularly sensitive to lateral G and after a few bends during a spirited drive will feel nausious but since i've started using this technique she hasn't complained. You do have to be better prepared before entry into the bend which requires you to be thinking ahead which is not a bad thing in any case.
My understanding of Double Declutch is that it only applies to non-syncromesh gearboxes when changing down. You lift the clutch while the gearbox is in neutral and blip the throttle to spin the gearbox before engaging the gear to match the gearbox input gear speed with the output gear. The aim is to avoid crunching the gearbox. The trick is to blip the throttle the right amount to get the speeds right. If done correctly you should be able to engage the lower gear without using the clutch. I don't think it's a technique employed to help you drive faster like 'heel & toe' is - it's just about preserving your gearbox.
