Picture of Car
- Thread starter IainCameron
Seeing as several members are reporting the same problem, there must be a common reason. Could it be file permissions?
Gary
I have just looked back at the mail I placed for help with my picture and it seems I was not alone.
Thanks again to Mike Butler who got me on the right track. I think there should be better instruction within the site to help all of us.
regards to all,
Iain
Keep trying the rest of you, but as already noted essential to make sure size of picture and pixels are under the limits stated (both must be right not just number of pixels) and ensure you have unchecked the box marked ' use your avatar as profile photo' , should be fine then.
Mike Butler
I have been tempted with the lights upgrade, including the rear but not sure if it is worth the money or I could get away without her indoors noticing and demanding a new dress in compensation!
Talking of lights, I have litronic headlights and they are absolutely brilliant, going back to my standard mitsubishi headlights on my company car is like suddenly driving in fog, if you haven' t got them I would certainly recommend you get them but perhaps at next car change rather than swap the current ones as I believe they are very costly!
I agree that it' s sad that they stopped Zenith... I can' t understand why - especially as the added clear light-look really makes the car stand out!
I unfortunately haven' t got the Litronics (or experienced them ...yet).
I could fit them aftermarket (although they would not have the " self-levelling" gadgetry that' s calculated from feedback from the suspension).
Also, I' ve seen several Xenon upgrade kits available (approx £500!!!!) but I am told that this would consitute an MOT failure (due to lack of non-levelling feature) (????).
I' m really pleased with my ' 03 spec rear lights - very cheap upgrade at £120ish (got mine from Type911, but essential styling/porschapart etc also do them). They clean the rear of the car up no end! Fitted them in 10 minutes, but spent a while trying to get " both" rear fog' s working (there' s only 1 on the Boxster! [
There is a modification that you can DIY with the front lights - the amber around the inside of the indicator can be removed by heating with a soldering iron, and picking it out. It takes about an hour per side (so I have been told). I have seen the results and they are worth the effort - especially as the fitting of those silver look philips bulbs remove " all" the orange from the front. Very nice. Maybe when I' m bored I' ll give it a go!
Geri.
I believe this is correct - it is a legal requirement to have self levelling with gas-discharge lights. Due to the extra brightness additional care has to be taken to avoid dazzling other road users.
