I've test driven a 996t, which is now tempting me. It's a 2002 with just 26k on the clock. However, the servicing worries me as it has had 2 year service intervals, rather the the 1 year I expected. Should I be worried by this as it's just 3.5k miles per year. It will be inspected (and anything corrected)and have the major service done prior to sale.
pondering a 996 turbo
- Thread starter mr pg
John Ware
By "two year service" intervals, I take it you mean that it hasn't been serviced annually. Someone will correct my detail but if it has done less than 6000 (?) miles per year, an "Inspection" will be sufficient every alternate year to a service.
ie. Under normal use, your service history would show 12k, 24k, 12k, 48k, 12k, etc. Under low use, you could potentially see inspection, 12k, inspection, 24k, inspection, 12k, inspection, 48k, etc.
IMHO, if the mileage is genuine, I wouldn't be too concerned about a service every other year. If that is the case, it will be due a 48k next unless it has had one recently. Assuming all else is ok, negotiate on that basis
My car (2002 car with 29k when I bought it) was similar with the correct services although at irregular intervals due to the mileage and the first 48k service due.
stephen_wood
I have my porsche serviced every 2 year because i only do 3000mls a year. The service book says a service due every 12000mile or 2year what ever comes first. The service's would be minor then major alternating every 12000mls or two year what ever comes first. Also brake fluid change every two years.
ORIGINAL: a7smw
The 2 year service internal came from Model Year 2004; for pre-2004 if you have done less than 9K a year, you can get away with an annual check which I believe is minor service minus pollen filter; oil filter and full oil change (so just a visual inspection I beileve).
ORIGINAL: mr pg
It doesn't appear to have had an oil change in between the 2 years intervals, and also missed the last brake fluid change. It's a very clean car otherwise, and ticks the rest of the boxes apart from a lack of heated seats (for the wife of course!).
As mentioned you don't need an oil change annually if doing less than 9K miles; every other year is fine and with such low mileage it would have unlikely to have had more than 9K annually.
Brake fluid is a hygroscopic liquid - meaning that it absorbs water over time reducing its effectiveness. If it has been missed then just make sure it is changed before you purchase it and the brake system will be back to its maximum effectiveness...
I agree with Steve. 24 ignitions represents 8 engine revolutions. At 7000 rpm, that works out to 0.0011 minutes, or 0.068 seconds. That is obviously one premature downshift for a miniscule amount of time, once in 26,000 miles.
If you want a Porsche extended warranty those forays into rev range 2 may disqualify the car from getting one.
ashley
Mine has an extended Porsche warranty with similar, 38 entries in level 2. All by the previous owner. Discussed with Porsche at time of purchase and they confirmed nothing at all to worry about.
Are these always caused by downshift or can it be a reflection of hitting the rev limiter on acceleration?
John Ware
Level 2 are "over-revs during downshifts". They aren't a big issue in small doses as discussed. Mine has a level 2 of 162 sparks or 54 revs or less than half a second at 7000rpm. It still seems to work. Given that the same block, albeit with titanium conrods, will rev to 8200rpm safely in a GT3, 7000rpm in a Turbo isn't going to cause a problem. [
Level 1 are "rev-limiter on the way up", of which mine has none. The rev limiter is set below what will cause damage so they're irrelevant in engine terms although may point to signs of an abusive life.
A PCGB member just bought a 996 GT3MKII and was refused a warranty for a similar number of Range 2s. I guess it pays to shop around.
Just out of interest and for your perusal here is another angle to the type 2 overrevs
http://www.pistonheads.com/gassing/topic.asp?h=0&f=48&t=858148&mid=173699&nmt=996TT%20Timing%20chain%20failure.
when I bought mine I had just 2 ignitions out of 1000 hours of operating time
ashley
ORIGINAL: John Ware
Level 2 are "over-revs during downshifts". They aren't a big issue in small doses as discussed. Mine has a level 2 of 162 sparks or 54 revs or less than half a second at 7000rpm. It still seems to work. Given that the same block, albeit with titanium conrods, will rev to 8200rpm safely in a GT3, 7000rpm in a Turbo isn't going to cause a problem. []
thanks for the clarification John
Just for reference:
996
RANGE 1, 7300-7900
RANGE 2, 7900 up
996TT
RANGE 1, 6750-7250
RANGE 2, 7250 up
996 GT3
RANGE 1, 8200-8800
RANGE 2, 8800 up
996
RANGE 1, 7300-7900
RANGE 2, 7900 up
996TT
RANGE 1, 6750-7250
RANGE 2, 7250 up
996 GT3
RANGE 1, 8200-8800
RANGE 2, 8800 up
Hi John
what had really interested me about that thread was the chains going kapput
I had always thought the engines were indestructable obviously a relative term
I was so surprised I asked Tony Wright about it he admittedly said he had never heard of it
anyway sorry for hijacking your your thread Paul
Ps Richard
what was all the stuff with the 6 rev ranges for the 997 engine
I hadnt thought rev 2 was quite so high eek!
Ps Richard
