Steve Brookes
Moderator
ORIGINAL: C2dweller
Car hadn't had technical bulletin 9005 implemented, so I've implemented the modification this evening. Fingers crossed for tomorrow. This is the tie-wrap of the cable to the air flow meter (Have other people checked this is done to theirs?)
It wasn't done on mine so I did it myself. Pay attention to the other point in the TSB that tells you to ensure the breather pipes behind the AFM are secured to the firewall (it's the air flow in those that interferes with the AFM signal). The mod helped reduce my problem of the fuel being cut when under low load going down hill. It didn't have any effect on normal idling.
