Porsche Warranty
Andy,
Just to pick up on your point about the (Porsche supplied?) battery. I thought that parts supplied and fitted by Porsche themselves are covered by a (2-year?) warranty? If it has a part number, a battery is a part..!
I'd certainly go above your Porche dealership and take the issue up with Porsche directly.
Good luck..!
Jeff
Motorhead said:
Andy,
Good luck..!
Jeff
I agree with Jeff, irrelevant of whether the Warranty on the car covers the Batter, legally any item supplied needs to be ‘fit for purpose‘ and failing after 4 months would suggest it wasn’t. As the supplier of the battery Porsche should be required to confirm the reason for failure. This doesn’t appear to have been done. Normally a good supplier knows that cost to clarify the reason for failure is normally more than just replacing it so that is what they do! I think taking this at its most basic legal argument. You were supplied goods (battery) by a supplier (Porsche) and it would be reasonable to expect the goods to perform their designed function for a suitable period of time. 4 months would not in my opinion be a suitable period of time so the duty lies with the supplier to confirm the reason for failure so it can relinquish its duty of supplying another under their original contract to supply something which would function correctly for a suitable time in normal use.
Frim Citizens advice web page
[h2]You’re entitled to a repair, replacement or a discount[/h2] Make sure you return the item within 6 months of buying it 23 May 2018 . It’s easier in the first 6 months, as you won’t have to prove who caused the fault.
If the repair or replacement isn’t the same as what you bought, you’re entitled to a refund instead. You could ask for a discount instead, if you’d rather keep the item.
[h3]What to say[/h3]If you're confident the item's faulty, you can say something like this:
"Under the Consumer Rights Act 2015, goods should be of a satisfactory quality, fit for purpose and as described. My rights have been breached because the item you sold me is faulty. I would like a refund/repair/replacement."
If they say the problem’s your fault, it’s down to them to prove it. Tell them you know this - and ask how long it’ll take if they send it back to the manufacturer.
[h3]If you paid by debit or credit card[/h3]You may be able to get your money back through your bank if the seller’s refusing and you paid by debit or credit card.
Contact your bank and say you want to use the ‘chargeback’ scheme. Many bank staff don’t know about the scheme, so you may need to talk to a manager.
If you paid by credit card and the item cost more than £100, it may be easier to tell your bank you want to ‘make a section 75 claim’. It’s another way to get your money back.
[h3]If you’re still not getting anywhere[/h3]Take the following steps:
[ol][*]Use our complaint letter for faulty goods- it contains legal terminology and may help the seller understand that you know your rights.[*]Check if the seller’s a member of a trade association. Look on their website or ask them if you can’t see anything. Contact the trade association, explain the situation and see if they can advise you.[*]Ask the seller if they’re a member of an alternative dispute resolution (ADR) scheme - it’s a way of solving disagreements without going to court. A third party will mediate to try and reach a solution.[*]If they don’t respond, they’re not a member of an ADR scheme or won’t use ADR, keep a record of the fact that you asked them (and the date). You’ll need this if you end up in court.[*]Choose an ADR scheme yourself to try and solve the problem more informally. It’ll help you later if you end up going to court.[*]Take your case to a small claims court (or use the simple procedure if you’re in Scotland). This is a last resort and can be expensive and time-consuming. You should only do this if the item was particularly expensive and you don’t mind the stress and time of going to court.[/ol] https://www.citizensadvice.org.uk/consumer/somethings-gone-wrong-with-a-purchase/return-faulty-goods/
Thanks for all the responses I have penned my response to Porsche Reading this evening so fingers crossed !
Hi All
Sadly my 911 is back with dealer having failed to start, I am hoping they will replace the battery as they have tested the electrics and cannot detect any electrical leaks at all, i am convinced that their supplied battery is faulty, however that said could anyone recommend a more heavy duty battery please instead of the Porsche supplied unit?
997 Gen2 2010
Porsche GB not that proactive is wanting to replace although I have extended warranty and the battery was changed in order for me to purchase the extended warranty so rather disappointing!
Not sure I will renew warranty when they they come knocking for more cash.
Andy
As you point out you need the Porsche supplied battery to keep the extended warranty. They (the batteries) get a lot of bad press but mine is still on the original one ( now 8 years old) but has spent it's entire life on a conditioner when the car is laid up for more than a few days. Also I check the fluid levels regularly as I'm not convinced every 2 years when it goes in for service is frequent enough!
On the general question of keeping the extended warranty, I wouldn't be without it. Just got the equivalent of one of my 2 years back due to a broken rear spring ( both replaced) In fact over the 6 years of extended warranty I reckon I am in credit!
Thanks for the update, much appreciated, may I ask do you use the Porsche Charger or another one?
Andy
Thanks, they have assured me that the battery is OK so will purchase this in lieu of the cigarette lighter charger the reviews on this seem very good, assuming it turns itself
off when battery fully charged
Best Regards
Andy
Best Regards
Andy
As you will see from the link that Clive posted they more than just "turn off" but condition the battery and keep it topped up. On the unit I linked to there is also a "reconditioning" cycle which will breathe new life into an older battery.
