Power Steering Fluid
- Thread starter Big Les
I am currently hatching a plan to leave client site a little early this afternoon, pick up some PAS fluid on the way home (on a bicycle, I should add!) and do the job this evening. Sooner has to be better than later.
How much damage will it have done? Dunno. There's only one way to find out.
robwright
xenon
ORIGINAL: zcacogp
Yes, the seals are what are worrying me. Hmmm ....
I can't imagine you've done any harm whatsoever but I'd get the proper stuff in asap.
GL
I'm not confident I've got all the brake fluid out. I am confident that there is only a small amount left in there (I'm imagining that there are a LOT of small spaces to drain in a power steering system). And I'll probably drain and refill it again within a month or so to get that small amount out.
Not a great job to do - jacking a car on the street, in the dark while it is raining, on a cold evening isn't my idea of fun. Still, my fault.
Purely out of interest, how different are brake fluid and ATF? They are both hydraulic fluids, and are both designed to do a similar job. I can appreciate that they probably have a different set of additives (detergents and the like) and therefore could be significantly more or less caustic, but the base product would be fairly similar I'd guess. I am also told that DOT4 gets more caustic as it gets older, so the fact that I put fresh new stuff in the system will mean it could be worse ... fingers crossed for those seals and hoses, eh? (Thanks for your encouragement Ian!)
Oh, and I took it for a (1/2 mile) test drive once I had finished the job and I'm still not convinced it's significantly much lighter or smoother than before ... [
xenon
Also, the viscosity is different as you no doubt noticed.
bmnelsc
Sorry - ATF we should use is old GM fluid - Dexron II (and III IRRC) and compatible. Newer Dexrons changed the formula.
jonnyporsche
