I wouldn't care, I was just saying the other day that mine has never gone off and I wondered if it was working ok, now it wont stop!!
Went over to the lakes today, had an excellent drive over there but once at Windemere a lot of the roads were very wet, covered in leaves and apparently a lot of the area was flooded yesterday. Anyway the car was parked up for a couple of hours whilst we went for lunch then on the way back whilst in slow traffic on a dry road the ABS came on as I pulled up to a halt, no severe braking or wet leaves, just a regular stop at a dry junction waiting for traffic to clear and then at every stop thereafter [&:] no reason at all yet braking from speed was fine only when almost stopped would it activate.....
Then I caught a bit of a pothole and as the car pumped over it the ABS light came on the dash along with the big red light with the exclamation/warning mark on it, so I pulled over, still braked ok and turned everything off for a few minutes then decided to try again, started up and pulled away, no warning lights lit but still the ABS is cutting in as I stop, same as before.....
Have any of you lads had this before? I am suspecting a loose connection on a sensor perhaps!! What do the sensors look like?
