Good and bad day... Mainly good.
I fitted my new injectors from America..... They were not new but reconditioned, I'll contact "dr injector" about that later, not happy.
Anyway, I read all the blurb that came with them and they read like a "professional" set up. So I thought they would be ok to fit as they would have been reconditioned to spec.
Easy job to fit, car started 2nd turn. Ran ok. Let it get to temp then went for a run.
Wow, what a difference. It pulled from low revs and the misfire I had was gone. I drove for about 4 miles and it raced to 80 easily. As I got back to my road it was not running as smoothly. It was like it was misfiring again...
So, long story cut short, 2 injectors are 100%, 1 is about 80% and the other is goosed.
I did an injector test to prove the above. I tested all 8 injectors I have and got 4 good ones. I will try and get 2 injectors sent to me when I complain....
On the plus side I have now proven that my poor running was not an electrical fault as I originally thought but injectors all along.
As it sits tonight the car is running better than it ever has. It drives like a different car. The engine is pretty much spot on now.
My son is taking it away again for a week so it will get a good testing.
Here is my test rig... [
] It does work...
