ORIGINAL: Rodney Naghar
Very interesting.....did he give you an explanation of the figures and the effects?
No, no explanation...
The place we were at is more of an Evo/WRX/STI specialist....and during a VW Rolling Road day..
I only gatecrashed in he C4S as it had just had new brakes fitted all round and I was keen to put a few miles on...and my Golf GTI was nice and clean tucked up in the garage!
There are a few things I'm not 100% happy with, run wise...but it was done during a quick Rolling Road shoot out, so I can't complain.
The differences are thee to see though...and that's twice I've seen differences on this dyno alone.
The AFR curve is interesting as in the 'On' position the Lambda sensors are making the engine run so rich. Why is that?
No idea...
And to be honest, I'm not a true believer in the old 'wideband lambda up one exhaust' to get an accurate measurement...it gives an idea, but I'd prefer to see the AF ratio from a properly installed wideband, or tapped off the std sensor, as I'm led to believe they are wideband as standard.
None the less...there is a strange difference between the two curves, for an identical car, run 5 minutes apart with only the exhaust resonance changed.
Unless, like was suggested previously, the pulse tuning of the rear boxes is indeed affecting the engine to such a degree that it's visible from the AF ratios?
These are the first figures I've ever seen for a PSE, excellent post!
I'm glad you find them interesting...I certainly do.
It just seems that not only do you not have any power gains, but you actually see power/torque losses and worse MPG figures. Anecdotal evidence of people saying they feel more power with the PSE 'on' now seems right, but not because of actual power gains, but because of a power loss with it 'off'! Buyer beware.
I'm not sure about the losses aspect...
I'd need to check the car on standard exhausts to know.
My GTI reads low on this dyno compared to my 'control' dyno.
It reads 182 BHP instead of the more normal 195 BHP...so 13 ish BHP in 200 BH...or a possible 20 BHP in 300?
So, the engine is making standard power I believe.
Assuming this is the case, and PSE 'off'' makes the Porsche factory dyno'd 316 BHP... then PSE adds to this.
Or, as you suggest, PSE robs lots of power.
Due to TUV approval, and the way Porsche - like all German manufacturers - tend to play down the power, to some degree, I'd put my money on my C4S making standard power with the PSE 'off' and a bit more with it 'on'...but in order to not have to type-approve PSE, and not have to accept insurance penalties for PSE equipped 996 owners...I'd suggest the power gains are played down.
Might be wrong though...
Which, sadly, brings me back to another day on the dyno...and a spot of exhaust swapping, to confirm one way or the other.
