ok, im totally new to the Porsche so can anyone let me know, if my interpretation of this mod is right ?
on my 2000 2.7, i basically drill holes in both exhausts as close to the rear box as i can, and weld in some inch and half tube, and route that best i can around the box, and then enter back into the single outlet exhaust tip?
if this is the case, i have an idea that i want to run by you too
if in this tube, i was to add either side a 12v operated valve, controlled by a dash mounted switch, i could then, turn the sports exhaust off and have a standard sounding car, with the option of a loud button?
or am i totally up the wrong tree here?
