thirteeneast
I have worked with Actuators for many I mean loads of different applications.
And I can tell you this actuators seize but hardly ever brake with working and lube you can normally always get them going again even when they've not moved for years.
Im not saying there accessible on a PSE exhaust because I've not worked on the system, I'm just passing on what I know about Actuators.
Failing that they look like Vacuum ones to me and I've had loads on waste gates on cars that I'm sure would fit.
http://www.ebay.co.uk/itm/Turbo-Wastegate-Vacuum-Actuator-for-VW-Golf-TDI-with-Garrett-VNT-15-Turbocharger-/170994502332
Not saying that fits but just as an example its generic parts that manufactures use, Try to get some specs and research it.
Also try part no: "997 111 90 1 90" I think it might be the same.
