After 2 months off turbo shopping and research iv gone with gtx 3071 in a v band housing
Far from bolt on, but hopefully performance will far from standard.
Iv got two v band housing both tial 0.63 and 0.83
Current goal is around 400 hp as I'm going to be poor for a while now and don't want to strain the engine or stock clutch.
Which house do you think I should use? Start with 0.63 and if I need more or when I can safely run extra power go 0.83 or just go straight for 0.83
There was options where I could get the gtx fitted to a kkk hotside. This would have ment a bolt on exhulst set up with mod 2 the turbo mount. However the gtx turbine wheel is only 60mm base smaller then 26kkk at 64mm so would off required using 24kkk hot side I believe. Not sure on how this would relate to EGT and back pressure levels, with the fear off slight fab work need I went with the proven.
From what I can find gtx should be at 1 bar around 2.8 and capable off 500 hp. Plus can run higher boost if required due to the low back pressure levels.
Looking for around 400 hp on 1.3 bar could run 0.6 and be higher then stock power levels and spool around 2.4k not sure what surge will be like on such low boost. I don't think there would be any worse effects running 1.7 bar on this then runing 1.3 bar on 26/8 kkk
