Questions re:S2 to Turbo brake upgrade
Oli was too polite to rise to the notion that an S2 might not need brakes quite as big as those of a Turbo.
Does that count as a hat?
Nice try, but I see no hat; the S2 had the same brakes as over half the turbos ever made ... [;)]
You'll just have to try harder. Perhaps I can recommend you a good hatter?
ORIGINAL: zcacogp
Hence why they put bigger brakes on the other half - they realised the smaller brakes were not quite upto the task!
Umm, that logic would also explain that the 944 was replaced by the 968 and then (much later) by the Boxster as it wasn't good enough and the 968/Boxster were better ....
(Or maybe I should just knock your hat off, eh? [;)] )
ORIGINAL: zcacogp
and they used the same logic to ditch the bigger Turbo brakes and put the S2 brakes back on the standard 968 [&:]
Porsche eh? [:D]
The only comment I can add is many modern brakes are over servoed and often have some form of brake assist, so they will feel more powerful, particularly initial bite. The Porsche ones might need a harder shove to hang you on the belts,
Tony
