ORIGINAL: 333pg333
Without doubt, boost gives as much of a rush as many illegal drugs....only it's way more expensive!!
You know, I think your right!
ORIGINAL: 333pg333
ORIGINAL: 333pg333
It's not too difficult to build a car to take higher boost. I don't think you guys have access to E85 though yet?? That is the wonder juice. I ran my car regularly on 1.5bar and it also hit 2.1 bar a few times when a vacuum line worked loose. Building up the motor to take extra load is doable as well. Bigger headstuds, metal headgaskets, standalones etc...
ORIGINAL: barks944
What is made worse under boost that causes bore wear to increase? I'm guessing it might be related to increased heat or increased streching of the bores under higher boost. Is this issue made worse with alusil bores?
ORIGINAL: MarkK
My red turbo has been running 1.5 bar for a few years now,it gets used properly not just for a dyno glory run and i can say it has been incredibly reliable,last year it did two very hard 1200 plus mile trips to the ring and Spa.I reckon tuned properly and regular maintenance these cars are very tough indeed.
Exactly Thom. There's no real way of avoiding extra load increasing wear. Well, certainly in Alusil bores. With Steel liners you would minimise this dramatically.ORIGINAL: TTM
ORIGINAL: 333pg333
This is something I really am not sure of.
We are always limited to what the bores can take in terms of lateral load, so I don't understand how an engine could "take" boost levels such as 1.5 bar without wearing out cylinder bores more quickly than at 1.2 bar.
For sure we can run levels of boost higher than 1.2 bar and still avoid knock with high octane fuels such as E85 but the bores will still work harder and destroy themselves much more quickly than with boost levels lower than 1.2 bar, well at least when using Alusil bores!
