Race car spring rates, advice needed!
- Thread starter Mac944
Neil Haughey
http://eibach.com/america/en/motorsport/products/suspension-worksheet
The figure of 0.94 sounds like it assumes a motion ratio if 1:1 for our strut suspension (cos 20 = 0.94), an assumption which is only valid I believe for a strut setup with zero scrub. Having said that I can't remember now where I got the 0.8 from which sounds to low.
The 0.54 is a typo as it should be 0.56 for the rear as it comes from here;
https://www.paragon-products.com/kb_results.asp?ID=58
The guts of that article has been there for as long as I can remember (more than 10 years). Many years ago they had some stuff about it which I may have read on rennlist back then that the number came from advice given by Porsche motorsport to support turbo racers back in the day.
Neil Haughey
ORIGINAL: Mac944
Reprofiled cams
This bit is interesting Mac, can you shed any light on the cams as I have been looking for many years for a more aggressive cam solution. That and a non-forged bottom end is what holds the S2 back, the former because it prevents the car from making much power lower down and the latter because its needed to get the revs out of the engine safely.
Neil Haughey
ORIGINAL: Mac944
ORIGINAL: Masher
Can't help with your enquiry I'm afraid, but I would be interested in more pics and spec of the car (assuming I am not asking you to divulge your trade secrets!). Sounds and, assuming that is it in your avatar, looks interesting.
Mick
I think there are some pics floating around on the forum somewhere of the engine rebuild earlier in the year. There's lots of external pics on the Classic Sports Car Club photographers website and quite a bit of in car race footage on Youtube.
I've been fairly open with the guys in the paddock with the spec, I've not disclosed the finer details of course ;-)
267bhp
1055kg with fuel
Steel lined block
Forged pistons and conrods
Larger throttle body
Larger injectors
Reprofiled cams
Aftermarket ECU
Race wiring loom
Fibreglass front end
Polycarb windscreen and side windows
Hmm, that is interesting as others have said.
I am really not sure that I have heard of another S2 with anything close to 267 bhp or 1055kg!
Eric_Oz_S2
The info on paragons website is incorrect. The wheel rate is motion ratio squared which for the rear is 0.65^2 = 0.42. If you use the racers edge shock mounts which have the standoff to increase the lever arm on the trailing mount, the wheel rate is even lower.ORIGINAL: Neil Haughey
Ed when I had a good look over my front suspension in the garage I used the following guidance
Mac944
ORIGINAL: Mac944
Reprofiled cams
The cam reprofile is very mild and to be honest I have no idea if it's made any difference as I didn't test the original profile with other updates. My objective was to retain the hydraulic lifters (for now) to try and keep costs down.
I believe it's possible to get custom cams from the US which are much wilder but they require changing lifters and valve springs and to see any real benefit the head will need quite a bit of machining etc, so for me it was just too expensive.
Mac944
ORIGINAL: Andy97
I suppose most 944 are built to race across the various club series including Porsche Club which operates a minimum weight limit so I guess most guys don't cut too much away because it's unnecessary but there's a lot of parts and panels that can be swapped for lighter materials or deleted completely.
I don't think I've gone too mad but I think it's possible to get below 1000kg with a bit more nip and tuck [
Neil Haughey
Eric when we were building the car I asked my brother to try and measure the rear motion ratio by carefully jacking the hub, measuring how much one of the wheel studs moves and then measuring how much the spring plate on the coilover moves. He never gave me an accurate measurement as it is really difficult but I settled on the Paragon number as he was telling me its about 3/4. I would have liked to have done it again myself but its not easy. It also changes if one fits spacers and due to the banana arm location the movement changes the ratio as the arm goes up and down i.e. its non-linear.
I can remember this stuff being argued about endlessly many years ago on Rennlist. I will say one thing though I have learned, one shouldn't worry about exacting these measurements or calculations as the characteristics of the dampers you will be using makes such a huge difference. The Gaz shocks and it seems the earlier Ledas as well both show on the shock dyno loads of low speed bump and rebound on the rear but very little on the front struts, this is a fundamental reason why we all seem to end up using relatively much stiffer front springs than rear when compared to some other solutions people have used over the years. Ultimately no substitute for track testing and development.
Neil Haughey
edh
The augment cam is for an 8v, I have never seen one for the 16v engines.
FWIW The KW clubsports us 90Nm F 60Nm R I think, much stiffer on the front than their v3.
Neil Haughey
ORIGINAL: edh
Tell me where I find the markings and I'll check mine if you like.
