This is just the 930 brake upgrade with 993 calipers - though it is nice to see that it fits inside 16s. I always thought 993 calipers on 930 rotors were too big for 16s but that is obviously wrong. One note of caution I would add is that the front wheels on that car look like 944 Turbo Fuch which have more room for calipers than 911 Fuchs. To my eyes, it looks like the wheels have the recessed lug nut holes - hence they are 7 or 8x16 944 Fuchs. These are very rare in the UK so good luck finding some.
I seem to recall reading about a 3.2 with 993 engine and 993 brake in 911 World which had the 7x16 944 Fuchs. I also believe that Josh Sadler's Autofarm RS had this brake set-up (with a 3.6 Motec engine!!) and the artcle said that car had 7.5x16 Fuchs - which sounds like a custom banded/welded wheel.
The great thing about this kit is that it is a reasonably priced bolt-on kit. If you can source all the discs locally (no reason why you can't get Wilwoods in the UK) you could just ship the rest over from the US for a very good price. Other than the discs, all this stuff is quite light weight. I copied the price info:
The kit included:
rotor adapter X 2
Caliper adapter X 2
Caliper adapter bolts X 4
Caliper bolts X 4
OEM 1998 993 Front pads w/out sensors X 1
NAS bolts, K-nut rotor mounting X 16 each
UL-32 Directional Vane rotors 309mm X 32mm X 2 each
Total: $415 plus Shipping
GT Directional Vane Gas Slotted rotors 309 X 32 X 2 each
ADD: $235
To this you need to add rear rotors (stock 930 readily available), almost certainly new brake lines are needed, rear pads and of course the calipers. You also need to remove the rear proportioning valve, the rear calipers need the throats opened to fit over the 930 rear discs and, I think, the mounting bolt spacing needs to be filled and re-drilled and you need a 930 master cylinder. You probably also want to rebuild the calipers. IMHO, you will still be closer to £2k than £1k once you are done and dusted. This set-up is arguably the best brakes you can get for a 3.2 and it sure looks pretty. I doubt however that it will stop any better than my 964 type set-up (in round number £1k all in), though I admit it has significantly better thermal reserves. It may be overkill for our cars.
HTH
Richard
