Simple answer on the discs is no. The Boxster caliper is designed to run a 24mm thick disc and a bigger diameter (ie., a Brembo or Alcon race disc on a zero offset mounting bell) would require a radial adapter to move the caliper out. You might be able to bore out the throat of the caliper to run a thicker disc but this may still not allow the use of say a 28mm thick disc which is the obvious Porsche OE disc (964 or 944T) and which would also require a radial adapter.
I would love to join you at Spa. Watch this space.
Richard
Richard
