I'm with 944man. Sorry. I suspect you won't be able to swap tyres from front to back as they will be different sizes, so that's not an option, but even if you could then you would then have mis-matched front tyres which is no better.ORIGINAL: 944 man
ORIGINAL: Outrun944
To close this off from my end anyway....
Should I consider switch the wheels over? And putting the new grippy tyres on the rear given it's rear wheel drive?
Is there an argument that you need as-much or more grip on front given when you break and the weight of the engine that's where all the force will be etc?
I am the antithesis of a PH tyre fascist, but I think it is obvious that you should buy two new tyres! You should also check your pressures regularly and read the road better.
Stump up for some new tyres and check the pressures regularly. If it's a while since it was last done then check the geometry as well (I'm surprised that no-one has mentioned this yet.) The joy of a 944 is in it's handling and you are missing the point of the car if you aren't keeping the chassis (i.e. tyres, pressures and geometry) in good fettle. And that's before you start to consider the dangers to other people of a car which you are not in control of. If you hadn't avoided the accident with the biker then how would you feel? And how would you handled a short conversation with his wife?
