Hi Andy,
I have a similar problem with some wheels that I bought. They are RS replicas but the ET is for a widebody car. I think the 993's Turbos came with a 47 offset. The standard rim is 55 so the turbo twists for they narrow body are 65 ET, pulling them some 10 mil inwards whilst the 47's go some 8 mil the other way. Coupled with wider tyres it doesn't work. As Ubertub suggests, you may get away with it by dialing in more negative camber bringing in the upper part of the wheel. Doesn't do your straightline traction any good, or your tyre wear, but it may get the wheels to fit. Firstt thing to do though is to check the ET on what you have. As Ian says, the ET will be stamped on the wheel next to the valve stem if they are OEM wheels. If not, it may be on the inside on the spokes.
GR
