appletonn
I wonder if I can persuade the 'clients' to all turn up in bikini's ...
I will......[8|]
[/quote]
OK, hands up if you've got an image.....?![:'(]
ORIGINAL: appletonn
[8|]I too bought the Dintrol stuff from Frost but also bought some small bore silicone tubing (about 1.5M was enough) and swapped the brass spray nozzle and the brass 'trigger button' piece from the supplied extension hose
I thought that the bungs allowed you to access the inner cills, whereas poking a pipe along the vent holes only got to the outer cills?ORIGINAL: Diver944
Saves peeling the carpet back and messing around with bungs []
ORIGINAL: zcacogp
How does the the dinotrol 'leak out' after you had finished injecting the sill? I thought the sills were fully enclosed sealed sections?
No need to remove the trims - just poke youtr head right 'round underneath them. You'll see them.ORIGINAL: sc0tty
Thanks Paul, looks like I will have to remove the plastic sill stone guards to find these holes, I have never noticed them before.
Scotty,ORIGINAL: sc0tty
This must be it then:
Perhaps, but you are still the guru, Sah!ORIGINAL: Diver944
Me an Oli are so on the case []
