Chaps,
A minor thing but someone here must have the answer - the retractable blind in the boot of my S2 is not retracting as it should. If you pull it out then there is resistance to the pull, but it seems not to want to retract as it should. You can make it work, but it usually takes a couple of 'jerks' to get the mechanism to do what it should.
I know that these things are slightly problemmatical, but is there any way of dismantling it to see what is going on, or is there an easy fix for this? (Or should I accept that it is failing and more of a hassle than it's worth?)
