ORIGINAL: jason
996 GT3RS must be one of the rarest of all the RS?
Are you forgetting your 964RS variant and all time Favourite again? The Oxymoron RS!!! 1 of 7
ORIGINAL: jason
ORIGINAL: jason
Never seen the spec sheet but I think many people BELIEVE a 964RS is very similar to a Carrera 2 when in fact some of the differences are......
Suspension:
- Suspension lowered 50mm front, 40mm rear
- Adjustable Bilstein dampers
- 40% stiffer springs
- Uniball solid top mounts
- Wheels 7.5" front and 9" rear Cup design magnesium alloy (ET55)
- Adjustable anti roll bars front (24mm, 5 way adjustable) and rear (18mm 3-way adjustable).
- Modified rear trailing arms "" shorter/limited travel
- Rear control arm adjustment plates are modified and are different left and right.
- Stiffer Lower Control Arm Bushings
Engine/Drivetrain:
- "˜Blueprinted' M64/03 engine which is a standard Carrera 2, 3.6l but using matched pistons and barrels.
- Single mass flywheel
- Single belt fan/alternator drive/pulley
- Flattened suction oil line "" oil tank to engine "" improves tyre clearance
- Solid rubber engine mounts
- Revised ECU adding 10bhp making 260bhp total (more aggressive timing advance characterstics)
- Hard rubber transmission mounts
- G50/10 gearbox with limited slip diff (Standard 20-100% Variable lock)
- Revised gearing: Shorter first and second gear ratios:
- First: 3.154
- Second: 1.695
- Third: 1.407
- Fourth: 1.086
- Fifth: 0.868
- Syncronizers made of steel, Modified for Quick Shifts
- Ring & pinion ration 3.444 (standard C2 is 3.333)
- Gear stick slightly taller and offset for a smoother shift ( offset 10 mm to left, 28 mm taller)
- Shift lever ratio - 3.4:1 (standard C2 is 4.0:1)
- Shift lever travel smaller - ± 52 mm (standard C2 is ± 62 mm)
- Driveshafts on the RS are hollow whereas standard C2 ones are solid
- RS driveshafts are longer to allow the use of centrelock wheels.
- Lightweight aluminium hubs
Braking system:
- Larger master cylinder diameter: 25.4 mm (standard C2 is 20.64 mm)
- Proportioning Valve Switch Pressure higher - 55 bar (standard C2 is 45bar)
- 3.3 Turbo brakes at the front and sport four pot callipers and drilled and ventilated discs.
- Rear brakes have four pot callipers but with smaller pistons
- Brake discs are cross-drilled and ventilated
- ABS is standard but features a modified ECU program.
- C4 style high pressure braking system with hydraulic booster / electric servo pump
Steering:
- No power steering on LHD
Body:
- Stiffened seam-welded shell - Seam welding and plating of the rear suspension mounting points, rear floor area, transmission and stabilizer mounts
- Removal of rear seat brackets, seat belt mounts, and trim brackets
- Aluminium front bonnet
- Aluminium stay to hold up front bonnet (no gas struts)
- No under-bonnet light
- Thinner gauge glass except to the front screen (3 mm versus 4.7 mm)
- Lighter doors with no reinforcing beams
- Wings have rolled arches
- Different middle section on rear bumper
- Front bumper has no headlight washers
- No bumper shocks
- Battery cut-off switch
- 36 AH battery
- Simplified wiring harness
- No central locking
- 77 litre standard or 92 litre long-range fuel tank
- Smaller 1litre capacity windscreen washer reservoir
- Front fog lights blanks (many RSs now have brake cooling ducts in place of the foglight blanks)
- No underseal
- 3 year anti-rust warranty
- Installation/modification of mounts for:
- Master electrical switch above the battery
- 1-liter windshield bottle in trunk
- Electro-hydraulic brake system
- Alternate mounting bracket for the ABS brain above the original location.
- Front tow hook
- Smaller 36-AH battery
- Inertial reel covers for the front seat belts
Interior:
- Leather covered lightweight Recaro bucket seats
- no back seats
- Lightweight thin-weave carpets with RS logo on rear bulkhead
- Minimal soundproofing
- RS steering wheel (RS logo horn pad)
- Lightweight door panels, no door bins, pull strap to open door.
- Radio optional - cars came with provision for fitting but no speakers and a simple blanking plate to cover the hole
- No interior light
- No heated rear screen (although the element there's no wiring or switch)
- No air-conditioning
- No sunroof
- No
- Manual winding windows
- Shortened front compartment carpet
- Simplified plastic cover for the front compartment bulkhead
ORIGINAL: vic cohen
Totally agree with Paul , + 996 or 7 rsr IMO cost a fortune to run either for a full seasons racing or a few track days ............totally disproportionate to 993 and before ...........................
ORIGINAL: Richard Dawson
That is cheating..... Though they are worth mega money
Reminds me of the yellow one I didn't buy in 2000
ORIGINAL: ChrisW
Well I am gonna find out --- as a matter of interest GT3R parts have been reduced in price by 65% --- they have too many and decided this was better than binning them ??
ORIGINAL: johnnyb
Looks very nice. Interesting to see that it was specced with a bucket for the driver and a sport seat for the passenger.... unless of course one or the other was fitted later.
ORIGINAL: roygarth
ORIGINAL: johnnyb
Presumably the original owners missus insisted on it...[]
ORIGINAL: vic cohen
Gearbox was the nightmare of a lifetime ......................worst experience in over 35 years of Pork!..............as a couple of people said on the day, something was moving inside that shud nt be ...................after much tribulation it came down to wear on the g/box bearing plate[ i did nt even know what that was .....u d be surprised not many people do !] This was compounded by finding out the exact state of what i had really bought when taken apart..........it really is nt the stuff for a Forum and i am not into international litigation ! Have spent that money on the car instead!
Gear sets are IRO £1500 a set, one of the problems was getting Weissach to find the right ones ............i repeat their records are nt what they were! This compounded with their suppliers machining things to wrong spec , not as per drawings ..................did nt exactly help. Once i got the right guy at Weissach things got easier but anything over 10 years old ur in the danger zone !
Tobe clear Weissach made a very generous cash gesture for all their mistakes and the litigation wud be against the so called eminent German builder .............everyone else along the line has done their best to help me
Now looking forward to following on great end to 2010, 3 stonking good days out before the snows , Silverstone , Donni and Goodwood in 10 days, with even better 2011 before i get too old !
