Hugh had a leak from two cylinders same bank when he had the purchase inspection .........
RIDE HEIGHT
- Thread starter PIRATEPETE
Be interesting to see your cams ... pretty sure they are 993 Cup
Hacki
ORIGINAL: h_____
I think you need to measure it, or better still have it done proffessionally. I assume that ride height and rake are important to the handling of the car. I assume that the RSs *must* have adjustable platforms making it easy to adjust, but you need to do it on a set of scales to be sure of the effect, well at least if you do trackdays etc.
I'd be much more tempted to get the car setup properly and have the ride hieght adjustment as part of that. That way, they can corner wieght it at the same time (As well as check the other geometry settings).
That´s exactly what I think and, yes, ride height affects the handling.
Hacki
