roll cages
- Thread starter j16jrf
944 man
I think that John Sims has one; so he might re-post his pictures.
Simon
lali
You could go half and half... welded in rear and bolt on front ( easy to take out door bars when you're not on track etc.. ) Speak to RollCentre I'm sure it was one of there cages I saw in thsi configuration.
I think you can still get an SD cage ( full bolt in ) from SD and then you need to find your local SD approved fitter. If you want a welded in cage then EMC will still do that for you.
I understand that these things come down to personal choice but I wouldnt trust one of those "bolts to the seat belt points" contraptions as far as I could insert one where the sun don't shine.
944 man
Neil Haughey
http://www.customcages.co.uk/homepage
Here's a Rennlist link to a guy in Thailand of all places who has installed one in his very nice project racecar.
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/493013-another-944-project.html
944 man
Well the OP didn't specify if they wanted bolt in or welded. I'm with Neil on this. Do it once, do it right but I get that this is probably the single most definitive line in the sand in regards to road registered / track cars. You don't want to be driving with a cage everyday so it is a big decision. Our road rules are getting more and more Police regulated that it's hard to enjoy having a nice car now. They're about to bring in a law here that if you get done for 2 speeding offences, you loose your licence. Yet they never actually discuss improving driver training as a matter of course. It's all just revenue and control. So I am about to turn my car into a track tool and will quite possibly go for one of these Custom Cages. They look very good from what I can see.ORIGINAL: 944 man
CustomCages only offer multipoint weld-in cages, no bolt-ins... Demon-Thieves offer Sparco and CC IIRC. As the OP is considering a rear cage its reasonable to conclude that he is looking at bolt-in types only, so CC arent suitable and Sparco are prohibitively expensive at approaching £1,000.
Any opinions on them?
Neil Haughey
Some of the cars in the PCGB championship are using the Custom Cages cage, its massively engineered compared to the Safety Devices design, and ISTR is around 10 to 15 Kg heavier. From memory at least one of the front running 968's had this cage. It looks good, very much along the lines of a touring car cage.
Neil Haughey
lali
ORIGINAL: John Sims
Another thing to consider is some insurers don't like cages and will either load your premium or not insure you. I assume it is because they think you feel safe you are more likely to have an accident.
I think its more likely to do with the fact that an impact at even very low speeds could see the driver 'nut' the cage and end up living the rest of his life considerbly disabled. i.e a massive 3rd party pay out.
I can vouch for the amount of trouble you have to go through to get a car with a cage insured, I have found that only Mannings will touch my car with all of its mods.
I certainly couldnt entertain the idea of having a caged car as my daily driver, the getting in and out is just sucha PITA that I'd end up setting fire to the car after a week!
Peter Empson
For me this has been the best compromise, I can bolt in front extensions to the cage if I want them at a later date (and doing it at the trackday would solve the insurance issue) and it gives me a sturdy location to mount the harness to. Plus I can only just get out of the car in a garage without the door bars...
