Rounded wheel nut
Try a hot air gun, then a centre punch and hammer.
If that doesn't work, I can only suggest drilling through the stud, but needs a steady hand and good kit.
Start with a pilot hole, gradually increasing the drill bit size. Once you're out to the actual stud size, the nut should come away quite easily.
Good luck.
Clive
ORIGINAL: sawood12
The undersize socket trick worked for me when I first got my car. After having trouble with the wheel nuts I decided that the alloy nuts after 20yrs had earned their retirement (some things are not intended to last forever) so I replaced with a full set of replacement nuts. I got them from a breakers who selects them for condition and re-sprays them. Apparently these alloy nuts are very sensitive to damage and corrosion and you should only use them with a 6-point socket and not a 12 point one as these over-stress the corners and ultimately fatigue them leading to the nuts rounding. I seem to think I spend about £20 for a full set of nuts and they were in near-new condition visually - though I've no idea how old they were.
Yes there is a tool you can buy not expensive for Porsche wheel nuts I have one and it does not mark them..
Got my locking wheel nuts from Porsche OPC about three years ago for £40 including postage and they have held up to three years of living and working outside even covered in snow and salt.
