RS Obervations
ORIGINAL: ChrisW
(I wonder if Will will be bringing along the tip I ordered ?)
Chris,
I don't think Will is coming to Donny, but I'll be popping in to see him some time this week, so will get him to give me your tip if he has it ready (expect he has). As i understand he has also finished a batch of the extra noise reducing bungs for the tip (or at least a working prototype), which I will have with me on Sunday for people to have look at ...............
Jamie
ORIGINAL: Jamie Summers
ORIGINAL: ChrisW
Chris,
Jamie
Thanks Jamie,
Chris.
Thought yours might be red Ian...have a pal over in Doncaster called Nick who has a Maritime RS...think you might have heard about him via a friend of a friend? He says that he's heard of someone nearby with a red RS. We should all meet up at a trackday sometime.
Matt.
ORIGINAL: ChrisW
ORIGINAL: ChrisW
Chris,
Jamie
Thanks Jamie,
Chris.
Chris,
I've just spoken to Will and your tip is in the post today (I believe he has texted you to confirm), so with any luck you should have it in good time for Sunday.
For anyone else interested in one of Will's tips, I will have two with me at Donny on Sunday - first come, first served ............. In addition I will have a working prototype of the extra noise reducing insert for the tip, which hopefully I will get the circuit marshalls to noise test for me on the day. Assuming all works to plan I can take orders for Will on the day. The idea is that the insert will be a push fit bung for the existing noise reducing tip which can be put in for static tests and then removed for actual track driving (as we know the 964 does not generally have a problem with driveby noise). Whilst it is not likely that it would cause damage to the engine it is highly recommended that the insert is removed before driving on track (manufacturer accepts no responsibility for damage caused if you don't etc etc etc). With any luck the insert should allow a 964 to pass even a 98db static test, so no track should be inaccessible any more (or even in the future). By way of evidence, an earlier prototype was tested at the Oulton RS day in March, and reduced a 993 Cup Car from 114db static to 100db static !!!!
Look out for me on Sunday - black RS reg J500 RSL
see you then .......
Jamie
You're right Matt, I have heard of Nick and his Maritime RS. Against the odds it seems we've got a bit of a S Yorks RS enclave going on!
