RS steering wheel
- Thread starter Guest
I've taken off air bag steering wheel before - was advised to disconnect the battery few hours beforehand - to rule out any risks, then you unbolt the air bag / central pad of the steering wheel ( 2 bolts you get to from behind the steering wheel - special type: T27 or T30s I think ) .
Once that is off - eased off slowly - as you need to 'un'plug' the air bag connector inside the wheel and the wire does not give you a huge amount of slack.
, then you will be able to see the main bolt that holds the wheel to the steering column ( 24mm I think )
other tip is to make sure your sheels are pointing dead ahead before you start the process - so you can line up the new steering weel when you fit it.
Hope that helps, T[&:]
Pickled Piper
pp
kbooker
Edited to say- The disconnecting the battery a waiting a few hours is bollox, they did the job immediatley with no problems.
ORIGINAL: kbooker
What PP said, Strasse in Leeds did mine for me, didn't seem as straight forward a job as what I thought it would be, some soldering involved and additional wires, and for what they charged it was well worth the job being done correct.
Thanks, I'll ask my local indie to see what they think, have an RS steering wheel lurking in the garage so might be a way forward
cheers
Pete
