RSR Spoiler
- Thread starter 356er
as mine is a non factory carbon fibre wing I would be curious to see this plaque[
Should I just delete the pic altogether??...If you need any detail, by far the best way is to take your own pics of real cars, it's hard to get a perspective of scale on a snapshot otherwise.
laquer and non laquer, once completed I will be looking for a stencil to etch the 'speedline for porsche' into the rim along with the offset numbers, anybody know where I could source such a stencil, I've used the stickers before and they are only a short term fix,
also ordered sets of 6 sided bolts in stainless from the same company, these are much cheaper than the 6 sided speedline bolts, the speedline bolts are stamped with a logo on the heads but as I said work out expensive for a full set.
I also have a carbon fibre lid I bought off herr schmitz some time ago, its actually in riviera too, must get round to fitting it.
Off to get my brake calipers refurbished now, paint removed, painted, pistons checked, new seals etc, painted & new stickers,
then laquered, anybody reccommend as to what brake pads I should use? im running standard at the mo, did have pagid but got
sick of the squeeling !
You should be able to get stencils made up by a local vinyl printer depending on how you are going to carry out the "etching". If you are going to do it chemically you will need masking materials specific to the chemicals being used.
Hi Nick, yes thats the company who are making the stainless rims and supplying the bolts, do you know if the etching is done chemically or perhaps sand blasted?ORIGINAL: Nick Moss
I get my wheel bolts from Pertsch & Partner GmbH - http://www.titanium-touch.de/home.php?language=uk
Totally depends upon how much track use and how hard your driving style is on brakes.
If you do a few track days a year, standard pads with spiders to keep the noise down are perfect along with decent dot 5 fluid, e.g. castrol SRF
If you were to spend more time on track, RS29 yellow pagids are the long life endurance pad to go for.
I have performance friction, which are ok, but make a lot of dust, I will go back to standard with spiders in the summer.
On the ammount of track use your car gets and the time you spend polishing your pride and joy, I see no reason not to stick with standard pads, they are also cheaper than the exotic track material.
ORIGINAL: Nick Moss
Apologies to the original poster, this has gone way off topic [8|]. Steve, I suggest you start a new thread....
Sorry, Mr forum administrator Sir!
Thought it might be ok to respond to the question asked?
I did try to delete my brake pad response, but was unable too, please feel free to delete it and this post as deemed neccesary
Thanks.
Richard Dawson
I have used Pagids in my 964rs and since then ebc yellow stuff. Lots of people claim they are rubbish. I have seen no evidence of this on trackday/Nurburgring and road use.
They are clean, don't make much noise, don't eat discs, last ok perform brilliantly and cost less I think than standard.
I used yellow all round; some specialists fit red at the back but this ends up with the rear pads melting so ignore such advice!
oh and thanks for the info guys .
