I have had very bad rusts (big holes) on both side sills and the wing panels. I only discovered how bad they are when I had the car looked into by a local welder for some other problems to fix where the MOT failed. He discovered that (by bloody peeling the rust off the sills in front of me [
]) the sills were badly rusted and the previous owner probably covered it up by filling them with plaster and then painted over them. He couldn't fix them and even if he can it could cost me at least £1200 (labour) + parts etc [&o].
So I ran up Richard of Porscha in the Midlands to get them looked into. The reason that I ran Porscha is because there was an article re 944 sills repair in the 911 & World mag sometime ago I read that they do custom made stainless steel sill and wing panels for the 944. I finally got it booked into to have both the rusty side sills and wing panels cut-off and replaced by their own ones (incl. welding, sandblast, rust proof underseal proxy and match-up paint) for a merely £500 + vat. Porscha has done a superb job and I strongly recommend 944 owners with rusty sill and wing panels problem. They also sell the sills and panels only if you prefer to do the works yourself. Check them out on http://www.porscha.co.uk/ and scroll down halfway on the main page right pane until you see the hyperlink
944 sill repair panels page £40
and then click to find out.
According to Richard of Porscha and he had seen a LOT porsches, the rusts are the worst in the S2 and turbo (and particularly the cabriolets - maybe something to do with manufacturing process) but the earlier 944 models are not that bad. He thinks it could be to do with the black plastic skirts under the sills which trap water and dirts that overtime rottens the sill area. I have removed them since after the repair job is done.
