random hero
I know the s2 has the same size calipers front/rear but someone has suggested to me that the front have a bigger piston is this fact or fiction ??
That could well be what I was thinking of.ORIGINAL: sawood12
Not sure if the S2 had exactly the same setup as the turbo, but the early turbo front calipers had piston sizes 36mm/38mm (upto '87) then 36mm/40mm.
ORIGINAL: Andy97
Can the 250 Turbo brakes (the big blacks - same as the 928 & 993, I think) be fitted easily to an S2?
ORIGINAL: Fen
I don't know I'd agree it's easy. I personally wouldn't like the idea of an adaptor holding my brake calipers on and there is an issue with clearance between the disks and the steering rod end as I recall. John Sims had them and took them off because he wasn't happy with them.
ORIGINAL: sawood12
I also noticed the few mm of clearance between the tie rod end and the disk but there isn't much more clearance between the caliper and the inside of my 17" wheel. I guess in engineering terms a few mm is a mile.
ORIGINAL: PJS917
Early type brembos had raised cast Porsche lettering, later brembos had painted on
Porsche lettering, all in the name of saving weight, or cost depending on your outlook.
