Hi Oli
I watching this with interest as my S2 has started to do the not starting hot thing. It will turn over fine and catch but is as if there is very little fuel getting into the car as it runs very quiet and lumpy with no power. Flooring the throttle makes no difference. Then its like it's flicked a switch and vroom off it goes no problem. Ive changed the DME and the fuel pressure regulator at the end of the fuel rail where the fuel lines attach. Also Changed the damper at the other ( front ) end of the fuel rail and the sensor for the water temp that sits on the head. Only does it when its hot and not even every time its hot.
BTW I have a bucket of frogs and a large tub of swarfega if that's any use to you.
