'Screech' noise when pulling away
- Thread starter BrianJ
pretzel
My '08 Cayman has recently developed a 'screech' noise. The noise occurs only briefly when pulling away from a standing start in conjunction with turning right and on an incline. The noise appears to emanate from the left rear of the car. This condition does not occur when pulling away straight or when turning left, or at any other time.
I have not yet consulted the OPC or local specialist as I thought I's seek the expert advice on here first. Anyone else experienced this and know the cause?
BTW I did search for this on Planet 9 and came across a post describing EXACTLY the same thing. The post there was dated 2009 but there had been no responses to date.
Thanks in advance,
Pete B.
pretzel
Thanks for that Brian, the noise seems a bit more 'mechanical' than that - difficult to describe really. I'll have the brakes looked at in any case. Pete B.ORIGINAL: BrianJ I'd guess small stone in the rear brakes. Had similar several times.
John H
pretzel
My Cayman is a manual. Did not mention that in my original post but thanks anyway. Pete B.ORIGINAL: flat6 If the noise is only when pulling away and you mentioned the incline, could it be a fault with the left rear brake in relation to Hill Start Assist? http://www.porsche.com/microsite/technology/default.aspx?pool=uk&ShowSingleTechterm=PTAnfA&Category=CATAnt&Model=&SearchedString=&SelectedVariant=
Hi Pete Hill Start Assist is standard on manual and PDK from whenever it was introduced. The link confirms that. Depends how old your Cayman is I guess, but not dependent on the transmissionORIGINAL: pretzelMy Cayman is a manual. Did not mention that in my original post but thanks anyway. Pete B.ORIGINAL: flat6 If the noise is only when pulling away and you mentioned the incline, could it be a fault with the left rear brake in relation to Hill Start Assist? http://www.porsche.com/microsite/technology/default.aspx?pool=uk&ShowSingleTechterm=PTAnfA&Category=CATAnt&Model=&SearchedString=&SelectedVariant=
pretzel
pretzel
pretzel
