Semi or fully synthetic oil..which one?
- Thread starter Axl Rose
sawood12
ORIGINAL: sawood12
It just allows the oil to get hotter and hotter once your cooling system has maxed out.
A thermostat would help avoid overcooling by acting as the 'switchable valve' you describe in your previous post, according to PET the part no. for the oil thermostat is 951.107.155.00.
Assuming I'm using PET correctly that should mean you could go nuts with the number or size of oil coolers & it should still be able to avoid overcooling [
Hilux
I believe Riverside is right. There is an oil thermostat, which is why those people who have fitted larger Mocal oil coolers do not run arond with oil that's too cold in normal conditions. The cooler does not come in to effect until the thermostat opens.
Ahhaaaaaa..........brilliant. Where is it? (too lazy to look[8|]) as I`m gonna change it as a precaution. Great engineering a syou can uprate the cooler without compromising the oil temp.
If thats the case then a temp gauge can be drilled into the sump plug or the turbo return pipe banjo (although the second option might give an artificially high reading for the general oil temperature) I`ll have a look at my spare sump and it may be possible to tap the sump or hole it with sealing washers and nuts each side. Failing that the logical place is an in line one to the cooler if its betwen the engine and the `stat.
sawood12
Hilux
All the one's that I've seen (Rennlist and our own Mr Cannell) have one on the sump plug.
How did Rick stop the oil coming out while tapping the plug [8|] .....................must have had to lay the car on its nearside [&:] [
