semi slicks
MichM3
Hi,
I drive the RS still on its 17" magnesiums... I do 1-2 trackdays a year with it. My Michelin cups are 3y old now and finished. I'm searching for a new set of semi's.
Which brand do you guys recommend? It seems there aren't many options left in 17"...
Mich
toyos arent as cheap as they used to be , but they are what I went for. I run 17s (why would you run anything bigger? Could consider Yoko 48s too. Very similar to R888s.
The Howells family rave about the Dunlops as do the 968 boys. Tbh the speed they go around corners when I'm on track with them I'd be seriously considering....
ORIGINAL: MichM3
R888 not in 205-50... will be 225-45 then... isn't that quite large for a 7.5 wide rim?
Will have to go out to garage and see what I put on - hang on....back soon(ish)
ORIGINAL: jason
...you're just getting slow Jason [:D]
Albeit a 968, cannot recommend the Dunlops highly enough. R888's go off too fast (on my e30 race car after about 4 short laps!), Michelins more for sprint racing and IMHO not for prolonged periods on track (full day on track in warm weather). Wear rate on the Dunlops is very good. They come at a price though, cost me £550 for a pair of 255 rears mid last year. (DZ02's were awful though, current DZ03's very good). Need to determine your use, part warns of any type mught be prudent. To spent c£1k on track tyres you need to be using them regularly!
Might be worthwhilst posting a wanted ad also - Michelins might be available from the championship guys (255 rears - can you fit 225 fronts?)
Jason - only done about 700 miles in the CS over the last year and becoming too familiar with the e30 so you might have a better chance now. (to be fair to Jason, my CS is rather track focused)
JP
I miss the Corsa R's... great tire in dry, long life... ok in the wet on normal roads compared to Michelin cup
Ok, so R888s, 225 front on 7.5 rim.
All good. I only use the car for trackdays, so short 15mins sessions, plus I dont drive it as hard as racing, tyres havent gone off yet. So fine for me for now. To be honest if you intend to have them on the car for anything like 12months (as mine) they'll go hard anyway. Racers will put fresh tyres on at the start of each season. I'm running mine until they need new (mid this year I hope!)
Hi MichM3....as you dont do a lot of track miles then cost of tyres is maybe not a big issue.
As Melv implies , there's no big case to go away from Michelins , they are more expensive than the others but are hard to beat on grounds of grip and overall performance.
They are too expensive for me though!! I used to use Dunlop D01J s which were brilliant , now not available in appropiate size replaced by first D02G and now something else ?D03Z ? .....which apparently work well.
I currently use Toyo R888 , as do many other people , so its almost a 'trackday control tyre' .
The 225 size will still work under front arches.
so if understand well, the toyo's go hard with the time... imagine I keep the tires 3 years, they will grow rubbish :)
...Quality tire is still the Mich cup then... will opt for those! thanks!
ORIGINAL: frogisland
JP
To be fair it was Big Dave and Graeme H who I saw at the RS day with them last time.
I think I saw you in my rear mirror, but you were too far back to be sure. ;)
ORIGINAL: MichM3
Mich cups are still available from new...
you drive slicks Melv?
Slicks for trackdays, need some stickies for sprinting, and Pirelli Corsas for 'wets', although they served me well in the Speed last year!![;)]
ORIGINAL: Melv
ORIGINAL: MichM3
Corsa R's still available?
haha lol!!! :).... shame production has ended... I still purchased a set for the GT3 last year.. great allround tire.
Did you guys already open a Porsche Day Spa topic?
I too like the Michelin Cups. Seem to go through several heating cycles and retain good grip. But this year, I'll go back to Michelin slicks--and take a bank loan [;)][;)]
ORIGINAL: MichM3
ORIGINAL: MichM3
Its not just the toyos, its all of them. I guess the point is if they are going to sit on the car for 12months or more, then relative merits of heat cycles and going off (very important if you race and need the extra time), become irrelevant as you will be running around on last seasons tyres. I bought mine in March last year, they are still on the car.
I used yoko 48s on the race car, and we always replace tyres at the start of the year, as they had gone hard and werent competitive. Not so important on a track car, hence relative grip levels of a new tyre for the NGT wasnt a concern - as its not going to matter as its old rubber.
