Shell Numbers
- Thread starter DSCBoy
Although Porsche quote a build date for a car, that is not the shell build date. It's the assembly start date (or possibly the paint date) - and probably the date the VIN gets created and allocated to the shell. The shell will be pressed and welded and dipped and primed before that date and just be part of a stock to be used on any car that can use that particular shell type (ie shape and cut-outs).
But as RS shells were quite special you can imagine someone accounting for them all and logging what happened to each and every one of them.
pncarrerars
ORIGINAL: pncarrerars
My RS (& maybe all porsche shells) has matching numbers stamped on the front cover, rear parcel shelf & rear cover.
What do you mean by front cover and rear cover ?
Thanks, Chris.
PhilRS
One can literally pear through the rear window, on right side corner of the car and read said shell number.
For the RSR, I am told that shells were taken off the production line and then sent to the racing department for the fitting of racing equipment. So, even though the VIN numbers of RSRs are consecutive the shell numbers of said cars have "gaps" between them. The magnitude of the gap depends on when the shell was taken off the production line and sent to racing department. So, there is still an order between VIN and shell numbers, but only VIN numbers are consecutive. For example, shell number of VIN car 34 will be (e.g. 100 units) smaller than shell number of VIN car 35, unless VIN car 34 has been reshelled, in which case it can have a greater shell number than car 35.
Dunno whether the same story applies to Ngt and cup cars.
Of course one can always write to Porsche to make sure that VIN, shell, engine and gearbox numbers do match. You will require a proof of ownership of the car.
ORIGINAL: clubsport
The Ngt & cup cars having no trim have a shell number dispalyed on the rear parcel shelf,,,bears no relation to the vin number as far as I can tell.
pncarrerars
Rear cover=engine cover=boot lid
lee fulford
Alex Postan
Also the engine lid has a matching number but with different spacing - '4 021 2'. It's on the inside of the engine lid, on the lip nearest the back window between the hinges. If you look up from the fan towards the rear window through the gap you should see the number.
I can't see any numbers on the doors but as the car is in the garage and it's raining I can't open them wide enough to have a good look.
I assume there's a number stamped inside the car somewhere - but is probably covered over with carpet.
I'd be interested to hear if anyone has either the same number, or whether you have matching numbers but different to 40212.
Could this be the body number - and does that mean each RS body was built with it's own individual and number-stamped engine lid, front cover and doors?
lee fulford
Think the numbers on the doors (if any) will be behind the cards.
DSCBoy
Given my rear parcel shelf is currently carpeted I´m stuck for the number there, so I guess its going to be the doors, which I am sure are original... so any ideas where I find the numbers on them?
Rick
Alex Postan
Come in No 6, your time is up.
Down Rover, Down[
(2200607)
ORIGINAL: Alex Postan
I am a free man and will not be filed, numbered or classified. []
Down Rover, Down[]
(2200607)
Or you could just contribute your numbers ?
We have just discovered how to tell if the front end and the back end of a car ties up with the middle --- a matter of some interest to owners and prospective purchasers ?
Chris.
DSCBoy
But next time someone tells u a car is all original panels it would appear we can tell whether it has had a big frontal or rear ended from matching the front and rear lids at least.
Any clues on where the numbers might be on the doors? Anyone?
