Short Shift
- Thread starter patch
SambaMav
Stu
No idea what its actually like, but if it does what it says it'd be ideal.
However, several guys on rennlist have gone for the stock 997 shifter in their 996's and seem to be very happy with it. Apparently results in about 15% shorter shift + much smoother change as the new shift assembly has been redesigned.
Heres a link to the thread:
http://forums.rennlist.com/rennforums/showthread.php?t=399323&referrerid=58247
I haven't got round to getting a price yet, but I'm very tempted as it looks like the perfect compromise. Any of you guys done this?
If you have a notchy gear change to start of with though it will make things worse.
scaramanga
when i was looking i found there were 2 available: the B&M one and the Porsche one. Apparently the B&M unit requires some cutting of the original components, so cannot be completely "reversed". The OE Porsche one can be removed and returned to standard (assuming you keep the original parts of course).
Re notchiness: i found the 986 standard shift to be quite notchy. the short-shift is marginally more notchy but the reduction in throw well worth it. just a personal view
Part number for the 997 kit is 997 424 983 00 - Should be around £256 after club discount.
The 996 kit number is 996 424 983 00 (Now unavailable) and superseded by the 997 part was £385.
Standard 997 gearshift was ~ £115 2 yrs ago via local OPC inc Porsche Club discount & is also reversible mod as comes as complete kit.
Have you considered the increased force required to change gear for the more extreme travel reductions - whatever travel reduction you go for is also the force increase.
Regards & happy hunting.
Paul
2004 996 C2 40th Anniversary
ORIGINAL: paulus
I fitted the standard 997 gear shift into my 996 - shortens the travel by 15 % - feels great & the effort increase is acceptable even with cold car in winter.
Paul
I will say they 986/996 SS kit can be heavy whereas the 987/997 SS kit is much smoother/lighter. I have installed and currently use both on our cars, very different feel.
