peanut
ORIGINAL: colin944
They are really easy to get off as they are held on with plastic nuts 10 ml if I remember right. You can get the nuts from VW as they use them alot and they are cheaper.The hard bit is putting the covers back on as you will find that a few of the bolts will come away as you remove the cover.I stuck mine back on with sikaflex but that made it really hard when I removed them again.
thanks for that tip Colin. Its a job I have been dreading. They are always wet or damp for days after it has rained. i dread to think what I will find under there. I may well leave them off and store the strips so that the wing and cill bottoms get a chance to dry out
