sawood12
ORIGINAL: Diver944
I'm no science geek but are we not forgetting that our cars have a simple air flow meter with a flap that measures air flow and adjusts fuel according to it's deflection. It has no clue about air density and when its at full deflection it will dump in the same amount of fuel regardless of how dense the air is.
This is right, the AFM measures air volume which is useless in terms of calculation of fuel requrements, but the mapping on the ECU will approximate fuel requirements from the volume of air measured by the AFM. Also the maps are adjusted according to the temp sampled upon startup. This is a very crude approximation of Mass Flow as the cars don't have the necessary sensors to measure the parameters required to directly calculate mass flow. So even though we have crude AFM's there is an attempt to approximate mass flow by the ECU. Obviously a MAF directly measures mass flow.
Again, i'm not sure how much the density of fuel reduces due to temp, but either way if the engine is demanding less air due to colder conditions then the demand on fuel delivery will be correspondingly less.
With regards RAM air. This is not really a realistic proposition on normal cars. F1 cars can only manage a small meagre RAM effect with hugely efficient intakes designed in wind tunnels. Aero engines only get a modest RAM effect at 500mph. The SR71 needed to be well into Mach 2 in order to get a RAM effect that was able to create meaningful compression of air - below Mach 2 it was running on afterburning turbojets before switching to RAMjets.
