Smoke from the exhaust on boost
- Thread starter marojojoem
You can check the AOS by disconnecting the breather pipe from the intake, use a blanking cap, and run the pipe into an old coke bottle or similar strategically placed somewhere in the engine bay while you go for a 'spirited' drive. i.e build up the revs and boost. Oil build up in the bottle will almost certainly suggest crankcase pressure from ring blow by.
I ended up replacing the turbo and rebuilding the engine! Hope you're not in that territory as it's not cheap, but I enjoyed the experience.
If they haven't been apart for a long time there usually is - might be worth cleaning them out and checking again after a 1000 miles or so,marojojoem said:Sorry for the saga here but on investigating the inlet ducting and hoses, there is quite a bit of oil accumulating around the intercooler inlet and outlet so unless I'm missing something obvious the turbo requires a rebuild. From what I can see the rotor and bearings are fine but I guess the seals have gone. Here's hoping its not too much of a mission to remove.
Tony
jonnyporsche
The joint to the crossover pipe has been apart relatively recently so I'm hoping that will be the easier of the two.
Thanks in anticipation
Mark
TTM
Well-known member
The downpipe must be separated from the rest of the exhaust by removing the 3 bolts you can see and one bolt that attaches its 3 bolt flange to the engine block, which again is non-accessible from above. For this exact bolt I have found that a 13mm pipe socket was the best tool, and having access either from below, or from in between the left side member and the wishbone (from which you won't be able to see what you are doing but should be able to feel it and proceed blindly).
Proceeding from below however remains the least tedious solution.
If you are able to remove the bolt holding the downpipe to the block then you could probably award yourself a beer or two, as it is in my experience and opinion the most tedious bolt to deal with on the complete car, at least when the engine is still in. Good luck.
Good how to on pelican parts - https://www.pelicanparts.com/techarticles/Porsche_944_Turbo/71-ENGINE-Turbo_Replacement/71-ENGINE-Turbo_Replacement.htm
