Hi
Wondering if anyone can help me with what I am assuming is a very rare problem (as cannot find anything on any forum) whereby my accelerator cable snapped on my 1996 C2 993. Luckily at the time I had only gone a short distance from home so managed to recover back to the house in idle!!
The problem that I now have is that having renewed the throttle cable...not an easy job for anyone with Varioram due to the much larger inlet manifold. I am struggling to get the set up right - and this is where my confusion begins.
I am using the Durametric diagnostic software to connect into the car and read the 'actual values' off on my laptop.
The 993 manual says that the throttle cable should be adjusted so that when you read the 'actual values' on the diagnostics it is at 0 degrees when throttle closed/idle and at 83 degrees when throttle fully open - unfortunately there is nowhere near that adjustment available and the maximum I have been able to achieve is 70 degrees...and that is with the pedal disconnected and the rod pushed as far as it will go.
The wide open throttle position sensor (actual values menu) is kicking in at approx 66 degrees but I just cannot get past 70 degrees.
Double checked that I have the correct throttle cable for the car (as there are approx 16 different variants available) and it is correct for year and model.
I then checked my brother's Porsche 993 C2 carrera 1997 model and found to my confusion that the fully open throttle position is 44 degrees (ie pedal to the floor). As far as we are aware the throttle has never been changed on this car as it has only doe 33,000 miles and had 2 owners...so would have to assume it is set up correctly?? His is also the same in that the wide open throttle detection does not change in 'actual values' menu as it does not go past 66 degrees.
The only thing that I can think is that the 83 degrees listed in the 993 repair manual is for the tiptronic models - and that the manual version requires a different setting? Does the wide open throttle detection play any part with the manual models...or is it only a feature required for the tiptronics - as they also have a kickdown switch for hard acceleration??
If anyone knows the answer to this - or has a manual C2 993 with varioram and has the appropriate software to check these actual values then I would really appreciate a comparison...as I am totally baffled by this.
Heres hoping that someone will be able to enlighten me. [
Many thanks
Many thanks
