DavidL
Whilst enjoying the KW debate I decided I really needed some more suspension to use whilst I made up my mind. I managed to pick up some relatively unused (20K) stock turbo suspension from the same model year as mine. Cheap as chips (£100 all 4 corners). I am determined to change them myself and started today.
So I managed to get the rear lower nut loose but the top one is a bit more difficult.
Will some kind soul just reassure me:
The nut on the outside of the inner wheel arch is the one I should be trying to undo for the top mount not the one tucked up close to the bodywork underneath. Its the same bolt just different ends - I think. There is a picture in the Haynes manual (not the best I know but it does give one or two pointers) but its effectively upside down?
This bolt has done 20 years and 200K (I told you the suspension was fubared) so presumably changing it would be good - what with?
When I take the lower bolt out even if the damper is compressed a little by a jack presumably the whole trailing arm will drop - do I need to be particularly careful here not to damage the disc on the floor as it drops?
I haven't got to the front yet but the replacement parts are complete except the top mounts. Presumably I can remove mine and take the top mount off one and put it onto the other without have to touch the spring?
Fortunately I don't need the car for transport so it can sit on axle stands for a few days. I know its not really a hard job but there is much satisfaction in doing a few bits yourself rather than driving to the indie with a boot full of bits and saying there you go fit those!
Any advice much appreciated, especially on getting the damn bolts undone!
David
David
